About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
VI Task Manager
Quite often I find myself running a new bit of code which contains an untested modal subvi somewhere in it's bowels, to find that the when called the modal subvi doesn't exit. Clearly there's a little bug in my code, but now I'm stuck. The modal vi has all the focus of LabVIEW, I can't close the vi, I can't abort the vi. Nothing is accessible, including the Project Explorer window.
Now what I need here is a LabVIEW Running VIs Task Manager, which allows me to simply scroll down a list of open and running vis, and abort the one that's stealing my focus.
It would probably have to operate outside the development environment to avoid being supressed itself, but presumably a standalone executable can link into LabVIEW through the server port and access the list of running vis with server calls.
This would save me from having to use Windows Task Manager and killing LabVIEW (and potentially any unsaved work)
11 Comments
falkpl
N/A
This is very useful and I have a vi task manager that I use internally.  A crude one is not hard to implement
-Get all vis in memory, check state (Exe.state) of vis returned (remove the self reference) display in list.  Allow user to select one and  invoke abort vi on this reference.  I agree NI should just add this to the environment.
Ian_Phillips
N/A
I agree, I have had Labview hang due to a bug in my code, and no way of aborting execution apart from closing Labview.
falkpl, any chance you can post your vi task manager until NI add to Labview environment?
yenknip
N/A
If you want a ready made VI, check out Darren's post
JICHFI
N/A
Google chrome web browser does something like that with tabs. I totally agree with this idea.
muks
N/A
I wrote a really wierd code today with a lot of pop ups and was not able to abort it and worst i had many unsaved vis. Hmmmm this time ctrl (.) did help but if there was a hang then it could have been night mare....
So I am with you in asking "bring this on"
thanks for the link yenknip
inversion
N/A
I feel for you all in this situation! Just happend to me again.
this post is also related:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Abort-all-VIs-Button-in-Taskbar-Modal-Windows-Problem/...
TrevMrgn
N/A
It would be good if modal VIs were only modal with respect to other front panel VIs and that the block diagrams and project explorer were still accessible.
Silver_Shaper
N/A
Yes really this might be a good idea to implement
fabric
N/A
"It would be good if modal VIs were only modal with respect to other front panel VIs and that the block diagrams and project explorer were still accessible."
That is a cool idea! Could you post it as a new idea on the Exchange?
TrevMrgn
N/A
Done. See here
