FPGA code allows I/O references to be used so that code can be re-used/abstracted, like this
This could/should be extended to cRIO C-modules so that code can be re-used on multiple modules. This would require the 'cRIO Device' property node to return an array of I/O Refnums that could then be passed to subVIs or other modular code.
For example, if I have code for an analogue input module (say, NI 9205) which filters and processes the data, and I wish to re-use that code in multiple experiments I have to manually change the module name in each IO constant or node (Mod1/AI0 to Mod3/AI0) if the module moves or I need more than one of the same type.
Conversely, if the cRIO Device property could provide the I/O references, the code could accept a cRIO Device constant and the reusable code extract the I/O references. The code would then adapt from Mod1/AI0 to Mod3/AI0 as the cRIO device was changed from Mod1 to Mod3.
It would be added to these properties.
Richard.
