It will be nice to have a button on the front panel of a VI (may be in the top right corner, near the window-minimize / close buttons) that provides a quick, "X-Ray view" into it's block diagram. After opening a VI if you press this button down on the front panel, you would get a quick glimpse of the block diagram behind it while the front panel becomes semi-transparent. When you release the button the "X-Ray view" disappears. This will help the developer to quickly check the code behind any panel (when not needing to edit anything) without having to do a Ctrl+E and later closing the diagram. Also by pressing down the button, the developer should be able to drag the semi-transparent front panel around, over large swaths of the block diagram (typically larger than the front panel) to inspect all parts of the diagram.
