After placing a new graph, we might want to go to the plot properties dialog and change the color, label, etc. of the plots we want.
Bzzzt. No go! We can only edit plots that have been added in some other way. (by resizing the plot legend, wiring and running once with data representing several plots, etc.)
For comparison, have a look at the cursor tab. Here we can add and remove cursors at will.
My suggestion is to add the ability to add or remove plots on the plots tab properties page of graphs and charts.
It could look like in the image on the left.
In addition, a removed plot would revert to the system default. It should be possible ro remove all plots, which would simply remove any customization from the plots and a graph would look as if was dropped freshly from the palette.
Why bother wasting time setting the properties of a control on the BD when you can have an initialization subVI do the job and overwrite any modifications done willingly or not in the past?
Well, if you have unlimited time and resources, you can write an initialization subVI every time you place a graph. ![]()
In my case I placed a graph and I know I needed three plots: One with points, and two with lines of different color and line width. After placing the graph from the palette, I wanted to immediately setup these three plot properties. This dialog is much faster than constantly clicking on the legend and do one property at a time. I was surprised that I can only modify one default plot and there was no way to add more without first exiting the properties dialog and jumping through some flaming hoops.
That should not be necessary.
I am not trying to be clever, just wanting to learn...
BTW, this idea appears to have been suggested in the past already (see comment 1)
> Ooops. Some people lack follow up mentality... and others can't read correctly.
I have no idea what you are trying to say here. Is this related to the idea discussion in some way?
1) The guy indeed stopped at proposing a "remove plot" button. Logically, he should have proposed an "add plot" button.
2) I should have not extrapolated based on a diagonal sampling of his comment.
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
