User | Kudos |
18 | |
17 | |
10 | |
5 | |
3 |
LabVIEW classes are how you create new data types in LabVIEW. But part of being a new LV data type is having a front panel representation. Although users can write XControls for displaying their classes, and they can put those XControls in the palettes, whenever a user of their class chooses "Create Control" or "Create Indicator" for the LabVIEW class terminal, they get the cube display. In order to really add a new data type to LabVIEW that behaves as well as, for example, the Timestampp or the Waveform, there needs to be some way to associate a class with an XControl and say, "This particular XControl should be used as this class' default control/indicator whenever one needs to be built." (To prevent infinite recursion and load dependency problems, whenever you did Create Control/Indicator on a member VI of the class, users would still get the cube control/indicator.)
