User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
I've found nearly duplicates of this, but not like that in a general form.
It is very useful that on the BD, two of inputs of any block having just two of them can be swapped with Ctrl-click; it would be great if any two arbitrary connections of any BD block could be exchanged the same way. Perhaps, only inputs with inputs and outputs with outputs to avoid potential cycles.
A typical use case of mine is: So I have created a subVI, and then decided to swap two connectors, for clearer grouping. It is very handy to use the switcheroo on the connector pane of the subVI (http://forums.ni.com/t5/LabVIEW-Idea-Exchange/The-ability-to-move-or-switch-items-in-the-connector-p... ). Now, why can't I do just the same on the parent BD instead of rewiring?
