Jeannius
Super Strict Type Def
Type def with an additional Super Strict mode in which case even the actual values are copied across instances. Changing the value in the super strict type def (for example an integet type def being changed from 0 to 1) cause all values to be changed. It would act as a linked constant that auto-updates all instances. Maybe in this mode you can only create it as a constant or greyed-out control.
2 Comments
Darren
Proven Zealot
