LabVIEW currently has functions Format Date/Time String and Scan Value to convert between time stamps and strings. Unfortunately, these functions do not handle arrays of time stamps and strings. While this conversion can be handled using a For Loop, a specific function would be cleaner and probably faster. This functionality is currently available for other numerics and should be extended to time stamps.
I suggest modifying the Format Date/Time String function to handle arrays of time stamps, integers and floating point numbers as well as single values. An additional function Date/Time Sring to Time Stamp should be created to convert strings and array of strings to time stamps.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
