User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
We're witnessing more and more requests to stop LV hiding important information from us. In One direction we want to be able to know (and some want to break code) if structures are hiding code.
Others want LV primitives to give visual feedback as to how they are configured, especially if that configuration can have an effect on what's being executed or how it's executed.
Examples include (Please please feel free to add more in the comments below)
Array to cluster (Cluster size hidden)
Boolean array to number (Sign mode hidden)
FXP simple Math (Rounding, saturation and output type hidden)
SubVI node setup (When right lcicking the subVI on the BD and changing it's properties - show FP when run, suspend and so on)
Sub VI settings in general (Subroutine, debugging)
I know there are already ideas out there for most of these (and I simply chose examples to link to here - I don't mean to leave anyone's ideas out on purpose) but I feel that instead of targetting the individual neurangic points where we have problems, I would like to acknowledge for NI R&D that the idea behind most of these problems (Some of them go much further than simply not hiding the information, and I have given most kudos for that) is that hiding information from us regarding important differences in code execution is a bad thing. I don't mean to claim anyone's thunder. I only decided to post this because of the apparent large number of ideas which have this basic idea at heart. While many of those go further and want additional action taken (Most of which are good and should be implemented) I feel the underlying idea should not be ignored, even if all of the otherwise proposed changes are deemed unsuitable.
My idea can be boiled down to the fact that ALL execution relevant information which is directly applicable to the BD on view should be also VISIBLE on the BD.
As a disclaimer, I deem factors such as FIFO size and Queue size to be extraneous factors which can be externally influenced and thus does not belong under this idea.
Example: I have some Oscilliscope code running on FPGA and had the weirdest of problems where communications worked fine up to (but not including 524288 - 2^19) data points. As it turns out, a single "Boolean array to number" was set to convert the sign of the input number which turned out to be completely wrong. Don't know where that came from, maybe I copied the primitive when writing the code and forgot to set it correctly. My point is that it took me upwards of half a day to track down this problem due to the sheer number of possible error sources I have in my code (It's really complicated stuff in total) and having NO VISUAL CLUE as to what was wrong. Had there been SOME kind of visual clue as to the configuration of this node I would have found the problem much earlier and would be a more productive programmer. Should I have set the properties when writing the code initially, sure but as LV projects grow in complexity these kinds of things are getting to be very burdensome.
