About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Show VI Symbol in Windows Taskbar while coding.
I had this idea for a while and did not find anyone else suggesting it, so heres the Idea:
Usually I have many VIs open at the same time and its annoying to switch between them, because they all have the same symbol in the Taskbar, and all are named "Frontpanel of ..." (rest is cut off)
Why can't Labview show the VIs icon instead? Maybe even with a little label on the icon for frontpanel / block diagramm.
Or is there already a solution for that?
Hope you like the Idea.
