I was quite surprised to see that this is indeed missing from the list of things you can assign a shortcut to automatically. Maybe, as the lack of any previous comments implies, rather than a permanent shortcut the analyser should be made available via the Tools>Options>Menu Shortcuts, then if users wish to they can set up a shortcut (as I have done with the Distributed System Manager on my system)
Presumably you can't select it as a shortcut because it's a VI added to the menu rather than a built-in option. It might be possible that you this just isn't exposed the UI, but you could do it by configuring it directly in the LabVIEW.ini file. I never played with menu shortcuts, so I never checked.
If you really want a quick solution, your best bet is probably to create a Quick Drop shortcut, which you can use to call the relevant VI from the <LabVIEW>\Project folder.
