let me suggest an alternative: When choosing 'Select VI...' from the palette or Right-click menu I would like to be able to select a Snippet as well. I would prefer that PNG files would be shown by default, but I do not have a problem with switching to 'All files' or having Snippets (*.png) be the next option in the file type pull-down. PNG files without snippets can throw the usual error.
Unlike dragging snippets, this method *should* allow the code to be placed on the cursor for more controllable placement unlike the current drop and look-out below method.
> I usually only use "Select a VI..." when replacing a node. What would happen if you replaced a node with a snippet?
Hopefully the 'Blue Screen of Death' or the Bulldozer if you are on a Mac, that'll learn ya to try something so crazy.
Actually, I think the same thing should happen that happens when you try to replace a node with a palette item set to Place Contents, namely *Bonk* and graceful fail.
