It would be nice, if the Search Result window for the VI items (property nodes, VIs, indicators/controls) would be possible to put on the top view. Because, if there are many VIs opened, and user double-clicks on the item in the Search Result view window, focus is switched to the VI, which contains found item; and Search Result window is folded to task bar. It's quite annoying, especially when you have many items in the list, and you need to find some in some particular place in the code - you need to double click, verify searched item, find Search Result window in the list of opened VIs in the task bar tray, open it, and select another found item, etc.
In case, when Search Result window can be pinned to top view, it would be very user-friendly - user double clicks on the found items, he sees, where it is located on the block diagram, but he also sees at the same time all others found items, and he can directly go to the next found item in the list.
