shb
Save settings and auto save information in different files
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
Currently LabVIEW settings like
and auto save information like
last projects and
last VIs
are saved in LabVIEW.ini
Please split this up in two files (maybe LabVIEW.ini and AutoSave.ini). This helps to check for changes in the settings. I suppose to save the auto save information per user. (See this idea.)
2 Comments
JeanPierre
I have made a small Windows command script that allows to easily start a project with its own LabVIEW preferences files.
The command is
start "" "C:\Program Files\National Instruments\LabVIEW 8.6\LabVIEW.exe" -pref "%~dpn1.lv86ini" "%~f1"
It starts the project using a LabVIEW preference in the same directory where the project is located. If the file does not exist, it is created there (you can keep using the .ini extension instead of .lv86ini)
I then add this script in the Explorer shell for the lvproj extension to Open it with the RBMenu ("Démarrer" means Start):
LabVIEW, C'est LabVIEW
Darren
Proven Zealot
Status changed to: Declined
