It would be great if we could specify a set of VIs to run on LabVIEW startup. It could be similar to the Windows Startup folder in which anything placed in the directory will start before the getting started window. This could be useful for running certain tools at startup or personalizing the way the LabVIEW environment starts up.
Michael: I saw this while researching my idea and it would kind of work. My problem with that solution is that only one person/tool/entity can change it for a given computer. If the user sets up that VI with some initialization code and then some add-on comes along and changes that VI for their own initialization, then it kills anything else that was already there. My idea allows any number of init VIs to run without interfering with each other.
And with that I will go hide my head in shame for forgetting to blur things out... 😞
