I'd appreciate to be able to reset every channel of the NI-9361 separatly when channels are set to count edges.
The property node "Cnt.Reset" doesn't work if the task is running so it's quite unuseful to use it for this purpose.
And when the DAQmx Task is stopped it resets all counters.
