User | Kudos |
18 | |
6 | |
4 | |
4 | |
4 |
The property node will be executed in top to bottom sequence. Changing the sequence of the property node is difficult now. In the example shown, reordering from Available sequence to expected sequence will more steps.
Proposed Idea: There should be an option of reordering the sequence on the right click menu of property node as we have in case structure (rearrange cases)
Attached the images also.
