I work on a 32bit computer with 4GB of RAM.
My application has grown to a size, which causes LabVIEW to throw up an "out of memory" message and simply hang (eventhough there appears to be a whole Gigabyte of RAM still available).
This occurs consistently, each and every time I run an exe build, unless I completely close and re-open the project file before I initiate the exe build process (the issue still occurs sometimes even in that case).
When LabVIEW hangs, the only option is to "kill it" through the Task Manager, which is a painful waste of time.
Suggestions:
LabVIEW should be able to handle situations like the one I ave described rather than simply crash.
LabVIEW should be given the ability to unload all VIs from memory and release as much memory as possible before an executable build process begins. Perhaps the user should be given the option to select this when initialising an exe build.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
