See the snapshot for a visual clue.
Most often we need to browse to the palette of the base data type (in this case Bool, and not only the datatype of the wire (Array)), to search/insert/replace a function while coding. Here I wanted to bring the And Array Elements function from the Boolean palette by clicking the Equal To function's output, but it gives me an option only to the Comparison & Array palettes. I'd prefer the Boolean palette to be shown up in the options. 🙂
This suggestion should be considered in a very generic & more inclusive manner for all the use cases.
P.S.:- I did not see any option for BD category, so labeling under UI & Usability (since the BD is an User Interface for me as an App Developer using LabVIEW. 🙂 )
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
