It would be useful to have something like a referenced comment. You can place this comment in the block diagrams of several VIs of a project, and by editing one instance of this comment, it will change all instances at one time.
Example:
The comment describes the channel list of an application:
Comment:
AI_00: Torque [Nm]
AI_01: Pressure [bar]
AI_02: ValvePosition [%]
You place this comment in the DAQ-VI. But it would be helpful to have the identical comment in the MeasFile-VI and/or in the VI that combines the channel and scaling informations to a 2D-string array, so you can present all these informations together (e.g. in a multi cloumn list box or something else).
When you later add some new channels e.g., it will be annoying to edit all these comments step by step, something like a 'comment type def' would be a practical solution.
