User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
<ctrl-drag> on the diagram expands the code to create more space. This does NOT work if we are inside a script or formula node. I am not aware of any special handling of ctrl-drag inside these nodes, so I think it would be possible to assign a resize operation to it.
Code posted in the forum often has way undersized script or formula nodes (see picture taken from here) and there is an immediate need to enlarge to actually inspect the code. Unfortunately, ctrl-dragging inside the script node does not do anything useful, and simply enlarging the node will bump into surrounding code. It is tedious to do a few ctrl-drag operations outside the node before we can resize it nicely.
IDEA: ctrl-dragging inside a script or formula node should enlarge the node and move the surrounding code accordingly.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
