User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Quick Drop (QD) is a gift to me and I love to use it.
Recently I have come across an issue that would speed up my development by a simple improvement of the QD "insert" function (CTRL-I).
As you can see in the image inserted above, I have indicated two options: [1] and [2] which each have two circles that indicate the wires/terminals I need to select in order to use QDs insert function.
Currently only option [1] works which, usually helps when the wire continues through the VI but in case [2] the wire ends inside the VI and I need to manually reconnect the terminal to the inserted VI.
My proposal:
Allow quickdrop insert (CTRL-I) to also consider selected terminals and wires exiting VIs which are selected and consider this in the quick drop commands which wires the corresponding wire to the VI inserted.
Also allow multiple selections to be considered.
e.g.: in the image above "Msg to Host" also has a wire exiting it, I would like to:
