Based on discussion at the CLA Summit with Dave Snyder and others: The 'Standard State Machine' available through the 'New...' dialog is not a state machine at all. It needs to be called something else. Other implementations commonly referred to as 'state machine' are in fact not; As has been pointed out by Elijah Kerry: "State Machine is a misappropriated name for a Queued Message Handler."
I think this is worse than misappropriated; it's actually quite misleading. The main problem is that Commands (or Messages) and States are two different things and shouldn't be used interchangeably.
I propose LabVIEW ship with something similar to what I attached. Although it's lacking many of the features that a full-blown state machine ought to have, it does capture the basic premise: "A state describes a behavioral node of the system in which it is waiting for a trigger to execute a transition." [http://en.wikipedia.org/wiki/Finite-state_machine]
Those of you with knowledge on this subject, please comment here with suggestions for this code that might bridge the gap in making this a useful template for people who understand state machine design but also still keep it as a good starting point and learning tool for beginners.
The attached code is multiple files, since I used type defs for States and Commands. Replacing these with string constants would quickly turn the template into a single VI.
