It will be very helpful if you can add a method for table control to enable or disable a particular cell with given row and column number.
By default, row and column numbers for that method should be -1.
If user specifies only row number with out specifying column number, then that entire row should be enabled or disabled based on user input. Similarly, if user specifies only column number without specifying row number, then that entire column should be enabled or disabled.
Hope this helps.
Harika
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
