Hi, guys
Do you use Templates in LabVIEW?
You might have used VI templates in LabVIEW (*.vit).
You might have used control templates in LabVIEW (*.ctt).
You might even used VI templates and control templates together.
Why can't we create templates for complex libraries like project files or (class-)libraries?
For example:
I've created three template VIs which are connected to one control (TypeDef) template.
(The three VIs are for loading, editing and saving the data of the control template to a special kind of data.)
But using the VI templates will create a separate control (TypeDef) for each VI!
If I could put the Templates together in a library or project, It would make things easier,
because LabVIEW 'could' already know about the connection between the two template VIs
and the template control (TypeDef).
That's just a simple example which could get much more complex on whole project templates.
Until now I have to copy the project template and use it as I need to. It works somhow, but
multiple people using the same template causes much trouble (Someone always forget to create
a copy before changing it )
So there's the idea. What do you think?
Available with the Project Templates feature in LabVIEW 2012 and later.
