User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
During implementation of code, the algorithm and its implementation has to be tested and debugged in most cases many times. For debugging, probes are a very useful tool. But probes can only be created on existing wires.
If, for any reason, the developer wants to probe values which are not on a wire already (e.g. iterator of a loop), he has to create an indicator (or tunnel) in order to have a wire. Once the debugging is done, the terminal/tunnel and the wire should be deleted.
I find it would be much easier, if i could right-click the data output and select Create >> Debug Terminal. This terminal is part of the code, but once i close the probe, the items created by this option (terminal and wire with probe on it) are removed automatically.
Norbert
PS: I know that there was a suggestion specifically for the iterator of a loop. I understand the reason why it was declined, but i find that using VI Scripting, the above mentioned functionality could be provided. As i WANT to have the information of that wire during debugging, i require that terminal/wire in any case. Using some automated tool would ease the debugging process with the hope to decrease time required to identify the software anomaly.
