User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
If you are using Global Variables in a project, and you drag the control from the Global VI's front panel to the block diagram of another VI, the item gets placed on the BD as a constant. It is more desirable that this action drop as a global variable node associated with the dragged control. If either the global VI in the project or the global VI's icon is dragged to a diagram then the result is a global variable node, but then always defaults to the first control in the global so you have to manually change it (this default choice is natural as LV would have no clue which control you wanted, fair enough).
This idea is to create some way of moving a control from the front panel of the global VI to the block diagram of another VI in such a way that LabVIEW knows to drop a global variable node instead of a constant. Because changing the standard behavior for dragging a control from any panel to any diagram would result in user interface inconsistencies, the suggestion is that ctrl+alt+drag be used to indicate that the user is performing a special drag, and when this drag is from the FP of the global VI to the diagram of another VI, LabVIEW should drop a global variable node.
Note: before I get people commenting that GVs are bad bad bad and should be removed, this idea does not attempt to rationalise the need for (or hatred of ) GVs, lets try and leave that for a different thread.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
