now the percentile VI calculate a table with NaN-values as the NaN-values are numbers higher than +Inf. This is incorrect.
The percentile VI should propage to result NaN if one of the elements of the table is NaN.
(An other solution is not consider NaN values and return as result the value greater than p percent of the data values in the array, but it would create incoherences with all other VI which propage the "NaN value")
Here a screenshot of the a bad response of this VI.
Moved to CAR database: CAR 529474
