Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
In some other programming software environments, primarily text based, you have the feature "peek definition". It would be extremely useful to be able to right click a subVI, have an option also for "peek subVI" which shows an image on the screen, while within the mouse bounds, of the block diagram to the subVI, even scrollable..
You should probably be able to do this in LV 2015 - create a context menu plugin for this and when it's invoked launch a VI with a subpanel and use the method which lets you insert a BD in the subpanel. It should even let you edit the BD.
