Sometimes I do not wish to delete a file permanently or keep the path of the delete file for later restore. Usually this is done in Windows by sending the file to the recycler and getting it back from there.
Two possibilities to get this functionality into LabView:
- Add "Recycler path" to the VI "Get System Directory.vi" to return the path to the recycler. The file can than by moved to the recycler and eventually back again
- Add a new VI "recycle" to the files palette. It should work like the "delete.vi" and return the path to the recycled file in the recycler.
Best Regards
Martin
