If I have a path control on my front panel for the user to interact with, I will always show the browse button. This button makes selecting a path easy from a user perspective, and from a developer I know that the path they selected has some level of validity. So for instance I know that the path they selected must exist and be a valid path otherwise Windows won't let them select it, and the value change won't be triggered for the control.
But the user can manually type in text into the path control, and when focus is taken off the value change event will take place. The problem with this is the path they entered might not be valid, or may contain characters my platform doesn't support.
I doubt a user will manually type in text in the control often, they will use it as an indicator showing the path they selected using the browse button, but on the off chance that they type somthing and it isn't valid, my code might crap out throwing errors.
I can add code to check for a valid path, and I can add code to check for illegal characters in the path, but I'd have to do this for every path control on every UI the user sees. I could also write an XControl for this with a decent amount of work and hopefully meet my needs, but it would be nice if this were a native feature.
So what I'm suggesting is that the path control have an option, possibly in the browse options dialog, which makes the interaction with the control, only available by using the Browse button. This would ensure that any value change event will be from the user picking a valid path with the browse button.
