NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
gvholland
Parallel Execution Structure as opposed to Sequence Structure
Status: New
by Member gvholland on ‎01-19-2010 08:57 PM
I would like to propose the use of a stacked parallel execution structure.  Especially in FPGA applications, this will solve the problem of diagrams running off the screen.  All execution pages will run simultaneously as if independent while loops were scattered across the BD.  This idea potentially leads into a 3 dimensional visuallization of coding LabVIEW. Note: In the image, the pages are offset but should look similar to a stacked sequence structure.
Comments
by Member gvholland on ‎01-19-2010 09:00 PM
by Knight of NI on ‎01-19-2010 09:51 PM
Many years ago something similar came up: Basically a tab structure on the BD as a way to layer parallel code that has no data dependency.
The tabs could be freely named. For example, one tab could be named UI loop, one DAQ loop, etc. Instead of scrolling to edit different parts, we could just flip to a different tab. :smileyhappy: More tabs could be added as needed.
There could be shared input tunnels, e.g. for a queue that is configured outside the tab structure on the left and later accessed on multiple code tabs.
Note that this is just a way to arrange code and is purely cosmetic. It does not add anything algorithmic. :smileyhappy: The code would behave exactly the same as if the code from the various tabs were placed next to each other on the BD.
by Active Participant Mads on ‎01-20-2010 05:33 AM
Normally if there are too many parallell loops I would say it's better to make them sub-VIs instead...
by Member gvholland on ‎01-20-2010 10:54 AM
I agree that it is best to use a subvi when applicable.  However, it is more of a mess when you have many controls/indicators needing to be updated on the front panel during execution of that loop.  You could pass references but sometimes it doesn't make sense, especially when programming FPGA.  Thanks for posting.
by Member donkdonk on ‎01-26-2012 12:40 PM
I think I like the tab option as suggested by altenbach
by Active Participant X. on ‎05-17-2012 12:57 AM
There also was a recent suggestion of "layers" on the BD, although I never managed to get the OP to clarify what he meant by that...
by Active Participant Zafer.Depe on ‎05-17-2012 03:29 AM
Kudos if that structure looks like a tab with labels
@altenbach
Basically a tab structure on the BD as a way to layer parallel code that has no data dependency +1
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
131
86
75
68
68
