How often would you need to use a feature like this?
I've never needed to create an arrangement of 81 objects before. A handful of times I've needed to create a pattern of perhaps a dozen or so objects. Not frequenlty enough where I feld I needed a special command beyond just copying and pasting the object and using the already existing spacing and alignment tools to arrange them.
In a relative sense, I expect that I might use that about 30% as much as I use the typical align commands, but more importantly it would help me handle some really bulky and complex inherited clusters from pre-existing code.
In terms of relieving a pain - it would help things. It would be really useful when the alternative is really not.
If NI ever works on that, I would suggest they also include an option to align along a circle. It took me quite some time to achieve that effect by hand...
