User | Kudos |
6 | |
3 | |
3 | |
2 | |
2 |
Whenever I configure LabVIEW for myself, I set the Option for Revision History to "Prompt for a comment when the VI is saved". I've noticed, however, that when I update a TypeDef (.ctl), I am not prompted, and need to re-open the TypeDef, go into Properties, choose Revision History, and add it "manually".
While technically one could say that a TypeDef, being a .ctl, is not a "VI", the logic that would provide a Revision History option to encourage developers to document their changes should also apply (in my option) to TypeDefs, as well. You can "disambiguate" the Option by changing "VI" to "VI or Control". If there are other things (like Classes?) that might fall into this basket, this option should be similarly "expanded" to include them, as well.
