User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
If you create a strict type def of a numeric control and select radix visible and say change radix to Hex. When you drop the control on a front panel the radix is visible and the number is in Hexidecimal format. However if you drop this control onto a block diagram as a constant, the numeric constant defaults back to Decimal format and you must then right-click toi show Radix and change to Hexidecimal format.
If you strictly define the control to be in Hex format, the 'strict' type should be applied for the constant as well as for the controls and indicators. Cuurnetly it will default as Hex format for control and indicator, but not as a constant on the Block Diagram.
Using LabVIEW 2014
