Ben_Phillips
Newly created VI's follow convention of opened VI's in Windows window ordering
Status: Declined
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
When you open an existing VI, the FP is linked with Windows as the window before the BD.  When you create a new VI, this is reversed.
It sounds nitpicky, but it can slow me down a little bit when I have 20+ VI's open.
I actually immediately save and close a VI every time I create one because of this, and then re-open to get the ordering I want.
2 Comments
dthor
I agree that both methods should result in the same ordering. When a new VI is created, the Front Panel and the Block Diagram are both opened (with the BD being opened "first"). When a subVI is opened, only the Front panel is opened. The user must press CTRL+E (or whichever method is preferred) to open the block diagram, putting the BD 2nd on the Windows task bar.
New VI:
Opened VI (with BD opened after the VI):
Opening a new VI should open the front panel first and the block diagram second. I'd like the focus to stay on the front panel though:
1. Open FP
2. Open BD (by windows default, takes focus)
3. Set focus to FP
Darren
Proven Zealot
Status changed to: Declined
