Broken_Arrow
New Clear Errors VI would keep a History of Cleared Errors
Status: Declined
Declining this idea for the following reasons: This would introduce state into a VI used ubiquitously across applications, including VIs running as part of LabVIEW's editor itself. It would make a global variable a standard for LabVIEW programming. And it would turn a fairly light weight VI into one that has the overhead of an array copy on every invocation.
This proposed new VI would expand upon the Clear Errors VI, and keep a history of the error codes that have been cleared. Ideally, it would have a History Length input (not shown) that, when not wired, would default to 1024 errors.
Richard
12 Comments
dthor
I assume there would be a boolean input that would clear the list, yes?
Also, should it store the error text too? My vote is yes. Perhaps also a timestamp of when the error / warning code was added to the list?
When the history limit is reached, it's FIFO, right?
Broken_Arrow
I was thinking the History works just like a chart history. The older samples just roll off the edge. LIFO? FILO? FIDO?
Richard
kegghead
I like this idea, but would like the entire cluster be retained. FIFO.
Broken_Arrow
I thought of that, in fact had that drawn up at first but changed it. I'd be fine with either. If I have the code I can look it up. The error cluster has the boolean which would be redundant - they are ALL errors.
Richard
MaryH
Status changed to: Declined
Broken_Arrow
Well, my Idea was for a NEW vi, not to edit the existing one. They could exist side-by-side on the palette. But sure, yeah.
Richard
dthor
"It would make a global variable a standard for LabVIEW programming."
Wouldn't it use an action engine instead? Either way, I like the Idea and I'm going to make one for myself. It will make logging errors much much easier.
dthor
Alright, here's what I've come up with. Feel free to use it. As you can tell by the timestamp of my previous post, I didn't spend much time on it, so it might not be ideal. Seems to be working OK though.
Clear Errors with History.vi
Clears any error entered into Error In while recording the timestamp and errors (not warnings) that enter the node. Reset will clear the list of errors and will also update the History Length.
http://dl.dropbox.com/u/431026/Clear%20Errors%20with%20History.vi
**EDIT: Saved in LV2010 SP1
Broken_Arrow
Very nice, thanks dthor! Smiley Happy
Richard
SteveChandler
Trusted Enthusiast
Although it was declined I just saw this idea and gave it kudos. I think it was improperly declined because Broken Arrow was not suggesting modifying the existing Clear Errors but adding a new one.
LabVIEW 2012
