a) What sorts of applications would benefit from this? It is a very rare sort of request.
b) You can easily build such a control for yourself by creating an XControl -- just reverse the bits before you display the bits in your facade and reverse the bits again if the facade control changes value.
The best application are the big testers with a lot of binary ports and setup sequecely whole ports to reach the status of the machine.
Leave all in the boolean arrays is working with arrays and a little less powerfull or optimal.Possibility to switch ON clock wise labels of the bits esspecialy in the constants would be super for that kind of the work. Easy setup and by th ecopy very nice coment of the code. Instead of the structures with bits...
Not urgent, but very graphically and editable sutable work with this... XControls is possibility, but very big effort I assume to reach this with especialy constants in the code...(controls or indicator are extra, but if exists similar object for the Conrol, Exist also for the constant 🙂 Thanks for the answer I dont know where is the pool with for ideas only to the marketing developers....nothing urgent.
Here... you caught me on a good day. I actually needed to create a new XControl as part of a test I was doing... rather than recreate one I've done before, I built one for your request.
Take it and adapt it as you see fit. It doesn't cover your constant use case (LV doesn't have XConstants), but in many cases, the controls suffice to set the value and then you can do "change to constant" afterward.
Thanks for answer, but You are more quick programmer then I am generating Ideas.
So I saw first time how to build XControl, but this is not a solution of my idea and I think it will not be possible to do it...by this technology.
If you imaginate binary number you hav it in the Xcontrol and above all bits will be included together above of the control or constant clockwise text
of the description of the bits...nice graphically to esy document code by this... I hope it will be standard property in the future of the integer variables or constants. Thanks and see you...This is not so comfortable like I need. VlaPET
