User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
When a user would like to use a .NET assembly in LabVIEW, a constructor node is used. The assembly is selected. Sometime, there is a problem with the assembly, and the error "An error occurred trying to load the assembly" would appear. It will be better if the message is more informative. Sometime, when there is a problem with the .NET assembly, LabVIEW should be able to provide more clues in troubleshooting.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
