RigilKumar
Multi Select Quik Drop
Status: Declined
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
Hi
Currently in Quik drop pallette only one function can be selected. I would like to have multi select functions by clicking Cntrl button from the Quick drop pallette like this
Hi
Multi select Quick drop
Rigil
Rigil
5 Comments
AristosQueue (NI)
NI Employee (retired)
How would those appear under your mouse cursor? One big stack of functions? Horizontally laid out? Would you expect autowiring to already be run among them?
FraggerFox
I like this idea!
It would be ok even if it does show which functions are being dragged out under the cursor, only dragging the selected functions should put them on the Block Diagram.
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
stbe
Once QD is loaded into memory, it is so fast I can also hit CTRL+Space twice to get both VIs.
I certainly see problems when multiple selection is possible - especially with all the available plugins already out there ...
_________________________
CLA
Darren
Proven Zealot
I've been prototyping some functionality with Quick Drop where, with a certain mouse and/or keyboard gesture, Quick Drop would stay open and regain focus after an object was dropped, thereby allowing for multiple drop operations without having to press Ctrl-Space each time.  If I can get that working, I think it will get us pretty close to this idea.
Darren
Proven Zealot
Status changed to: Declined
