User | Kudos |
21 | |
18 | |
11 | |
5 | |
3 |
Radio buttons, rings & enums are used for the same basic purpose: to allow a user to choose from a list of named options, giveng the programmer an integer result. When trying out different UI designs I am unlikely to want to swap a radio control for a toggle switch or "OK" button. I am far more likely to want to swap it for a ring or enum control.
Currently, if I replace a menu ring with a text ring or an enum, I'll get a new control with the same number of items and the same item names. Often no DB editing is needed.
But if I replace one of those with a radio button control, I get a control with two booleans in it, and I have to recreate everything from scratch.
I'd like to be able to replace a ring or enum control with a radio button control and get a radio button control with as many booleans as I had items in the ring or enum, labeled with the item names. (I'd also like to be able to make that transformation back the other way.)
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
