(This is different and less controversional than this related old idea)
Arrays of timestamps only contain legal values and can even be sorted. We can use "search 1D array" to find a matching timestamp just fine.
As with DBLs, there might be a very close array value that is a few LSBs off, but well within the error of the experiment so it is sufficient to find the closest value. We can always test later if that value is close enough for what we need or if "not found" would be a better result.
If we have a sorted input array, the easiest solution is "threshold 1D array" giving us a fractional index of a linearly interpolated value. For some unknown reason, timestamps are not allowed for the inputs, limiting the usefulness of the tool. One possible workaround is to convert to DBLs, with the disadvantage that quite a few bits are dropped (timestamp: 128 bits, DBL: 64bits).
Similarly, "Interpolate 1D array" also does not allow timestamp inputs. In both cases, there is an obvious and unique result that is IMHO in no way confusing or controversial.
IDEA Summary: "Threshold 1D Array" and "Interpolate 1D Array" should work with timestamps.
