New propety node or modfication of the existing property nodes for strings.
Enable a Vertical slider to stay locked at the bottom of a string as it grows, for instance when dumping data into a growing string as part of a loop, however if the user wants to scroll to review something they can. Currently the easy way to make a slider stay at the bottom is to wire a very large number (inf, or -1) to the property node for slider position but this doesn't allow the user to go and review previous data, as the slider fights each loop iteration to return to the end.
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
