NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
sabi_s
Marked broken Vis in project explorer
Status: New
by Member sabi_s on ‎06-19-2012 05:51 AM
Placing a visual mark (e.g. a red dot) next to broken Vis in the project explorer could help to identify possible issues in an easy way.
Comments
by Knight of NI on ‎06-19-2012 07:17 AM
If the VIs are loaded into memory, then the broken VIs appear at the top of the list in the error window with a red X. Isn't that good enough?
by Trusted Enthusiast on ‎06-19-2012 10:19 AM
I like it. Even though broken VIs are listed in the error window, this is just another way to spot them. And since the project explorer already has the information it should not be very difficult to implement.
by Active Participant yenknip on ‎06-19-2012 10:49 AM
I'd also like to add a TODO note to VIs in the project explorer. At the end of a day, to prevent forgetting my TODO labels, I drop an unwired numeric operation next to them. find broken VI -> find todo note.
by Knight of NI on ‎06-19-2012 11:38 AM
Two things I don't like about this:
  1. The VIs in my project are generally in a hierarchy. For broken VIs I prefer a flat list. If I'm looking for broken VIs it's probably because I intend to fix them, so I might as well be going through them one at a time.
  2. I really don't want the project window to get too noisy. Maybe if it had additional columns, this could be an optional column, but I wouldn't want it as an icon or an overlay.
by Trusted Enthusiast on ‎06-19-2012 12:38 PM
I can see your point about the noise. Just to be clear I wouldn't want this idea to replace the list of broken VIs in show errors.
by Active Participant SnowMule on ‎06-19-2012 02:02 PM
Maybe something like Show More VI Properties, just adding another column for compiled/in-mem/broken?
by Trusted Enthusiast on ‎06-20-2012 08:06 AM
The project doesn't already have this information. The project lists all the VIs in your project, whether loaded or not. It doesn't know anything about the broken status of VIs that are not loaded.
by Trusted Enthusiast on ‎06-20-2012 08:31 AM
I meant the project explorer as in the whole IDE, and that the program has a list of broken vis in the error window. I know that the project file itself is just a list.
by Trusted Enthusiast ‎06-20-2012 08:57 AM - edited ‎06-20-2012 08:58 AM
@AQ, I see what you are getting at. Since the project explorer can only list broken VIs that are loaded it would not be able to mark/show/highlight broken VIs that are not loaded. Because of this inconsistency I am revoking my support of this idea. It would be a good idea if it were possible so I will keep my kudos on it just in case you guys can figure out how to do it. I need to learn not to post with incorrect blood/caffeine levels :smileyembarrassed:
by Active Participant BillMe ‎06-23-2012 08:55 PM - edited ‎06-23-2012 09:03 PM
I'd like the entire path to the broken VI(s) tagged in some way to make it easy to find them. For example, make the foreground text of all path elements to the VI and the VI itself in red. So for any broken VI under "My Computer", "My Computer" would be in red along with all folders and lvlibs to that VI. I currently run the "Mass compile" option on the "Project: XXXXX" run-time menu to find all broken VIs in my project. I like it because it only compiles my project files, however, it doesn't display the dialog box with the logging option as the one under the "Tools...Advanced..." does. I like the logging option of the mass compile on the "Tools...Advanced..." menu but it compiles every VI in the path you specify rather than only your project files.
Or how about populating the "View...Error List" with the "BAD VI" results from the Project Mass Compile??
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
151
79
69
53
44
