User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
(There are much more comprehensive ideas related to the run-time engine install mechnism posted and they would solve all this too. Still, if the above idea will take al long time, the following mini-idea could hopefully be implemented earlier :))
A wrinke I run across with my users is that I clearly specify that they need to install the standard run time engine, however they go ahead and install the mimimum version for whatever reason.
Then, when they launch the application, they get all these warnings that are complete gibberish to a non-LabVIEW user. Warnings about missing VIs, ctls, etc. So I get phone calls and e-mails that things don't work.
My suggestion: The minimum run-time engine should be aware of the things included with the full run-time engine and give a single meaningful warning message that the standard runtime engine is required and only the minimum is installed.
