defering Panel updates is both useful and a bit tedious. You have to
fetch the Panel reference, and while you are doing your presumably
time-consuming operation, the entire panel is stuck. I suggest that
Deferring Updates should be a property of an individual object and not
just the entire panel. Wrap your operation with a pair of property nodes to
start and stop deferring and you are all set.
Conditional Kudos: change Idea from "Make Defer Updates an Object Property instead of Panel Property" to "Allow Defer Updates as Object Property in addition to Panel Property" 😉
I don't have a problem using Defer Panel Updates Property for Panels i.e. I don't think its tedious to get to the reference as per the original post.
I support this Idea as I do have a problem when e.g. I wan't to defer updates because a method running on a heavy UI object (e.g. Update Tree) takes a lot of time and deferring updates means that I can't e.g. provide a status update in another object. http://bit.ly/9wj8dG
In the same fashion, when You have multiple object instances (lets say multiple instance of an XControl for example) that need defer panel update concurrently, you have to jump through hoops to make sure one instance does not restore panel updating while another is in the middle of a large refresh that required update to be deferred. So big Kudo to that idea since having this on a per object basis will make that problem go away..
