User | Kudos |
6 | |
3 | |
3 | |
2 | |
2 |
LabVIEW should support loop unrolling...
For those who do not know what loop unrolling is (from wikipedia http://en.wikipedia.org/wiki/Loop_unwinding)
Loop unwinding, also known as loop unrolling, is a loop transformation technique that attempts to optimize a program's execution speed at the expense of its binary size (space-time tradeoff). The transformation can be undertaken manually by the programmer or by an optimizing compiler.
The goal of loop unwinding is to increase a program's speed by reducing (or eliminating) instructions that control the loop, such as pointer arithmetic and "end of loop" tests on each iteration;[1] reducing branch penalties; as well as "hiding latencies, in particular, the delay in reading data from memory".[2] Loops can be re-written instead as a repeated sequence of similar independent statements eliminating this overhead.[3]
Example with textual programming language:
int x;
for (x = 0; x < 100; x++)
delete(x);
Becomes:
int x;
for (x = 0; x < 100; x+=5)
delete(x);
delete(x+1);
delete(x+2);
delete(x+3);
delete(x+4);
Who is with me 😉
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
