Add a limitation for the minimum field width for numerics.
The maximal accepted value should be limited according to the format and the display style of the numeric. For example 2 for a U8 with hex display.
Currently, this missing limitation can lead to confusing code/display. For example, with a minimum width of 4 and "Pad with zeros on left", above numeric will have a "U16 look".
A particular thought would be needed about how to adapt the entered value when the format or the display style changes.
Not obvious. The cure could be worse than the disease !
What do you think about this idea ?
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
