User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I often get this dialog when a class is locked because a VI is still in use by some running process. It might be a reentrant process that for some reason didn't shut down as expected, but in a system with 3000 VIs and lots of asynchronous processes it can be very hard to guess what code is still running. And this dialog doesn't give much information. It would be great if this dialog could show exactly which VI (with full information of what reentrant copy of the VI it is) is still using the class/VI. Even better if you could click on the filename in the dialog to open the VI.
