User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
The getting started windows fills with irrelevant entries if we open many VIs and projects from the forum. We probably never want to see them again. Also, if items exist that have the same name, but reside in different folders, they will show with the full (often very long!) path and the filename is not directly visible unless we e.g. hover over it or make the window gigantic. Here we want to remove the stale one, even if a copy still exists on disk.
We can currently do some cleanup by editing labview.ini but it is tedious. (just try it!)
I would like to request a feature that allows us to easily and permanently remove any entry in the list.
(...maybe it could even show for pinned entries?)
IDEA: I suggest to show a special glyph that, when clicked would remove that entry from the list.
It could also be e.g. an "X" (or similar) that shows next to the pin when hovering so we can either pin or thrash an entry.
These are just some suggestions, but there should be a way to easily weed out unwanted entries from the GSW. Of course the actual files will not be touched. We would just go back to the state before we opened that item.
Re-opening because LabVIEW NXG has been discontinued.
